WTT FBP EM1 l k20z1 l k-tuned l hybrid racing l Work wheels l tein l everything tuck
I AM ONLY INTERESTED IN TRADING FOR A S2000!
2000 civic SI (clean title)
exterior
factory paint couple dings here and there
102k original documented miles
all oem exterior options
vis carbon fiber hood
vis carbon fiber trunk
oem ctr side view mirrors
brand new oem headlights
hid's
rolled fenders and quarter panels
interior
everything stock em1...
brand new headliner
modded Factory cluster ( Si emblem lights up )
carbon fiber cluster trim
motor
everything bought brand new
06' k20z1
skunk2 drop in cams ( no valvetrain needed )
06 z1 trans with z3 oem lsd converted to 02-04 vss
brand new oem throw out bearing
competition stage 4 clutch
hasport ekk2 mounts
2001 gsr subframe and ps rack
rrc intake mani
70mm bdl throttle body
k-tuned rrc adaptor
k-tuned ac-ps delete
k-tuned radiator
k-tuned swap radiator hoses
12'' slim fan
k-tuned ect fitting
k-tuned heater delete
k-tuned throttle cable and bracket
k-tuned clutch line
mugen low temp thermostat
hybrid racing fuel rail.. ( the fuel tuck version )
r-crew race header
550cc oem injectors modded. also have stock
sparrkss racing conversion harness
hondata prb kpro with on-board data logging
fuel lab FPR ( new version, just came out )
earl's -6an inline fuel filter
-6 an fuel feed line and -4an fuel return line
all fuel AN fittings are black ( more expensive than the standard blue and red ones)
all fuel lines a black nylon braided to match the fittings
brand new hasport axles
blox magnetic oil and tranny drain bolt
chassis/suspension
tien basic dampers
skunk2 gold lca's
new inner and outer tie rods
fresh alignment
itr 24mm front sway bar
brakes
all oem
wheels
Currently on car:
Rota Group N
15x7
Included in trade:
Work Miester S1
2 piece
17x8 38mm offset
wheels powder coated chameleon to make the valve cover and brake booster
Engine bay also has a wire tuck, a brake tuck, and has been repainted.All the car could use is paint since the one on there is factory.
Now on with the pics:
Serious inquiries feel free to call or text (239)692-7822 Chris.
exterior
hid's
interior
brand new headliner
motor
06' k20z1
hasport ekk2 mounts
rrc intake mani
k-tuned rrc adaptor
k-tuned radiator
12'' slim fan
k-tuned ect fitting
k-tuned clutch line
r-crew race header
chassis/suspension
tien basic dampers
skunk2 gold lca's
fresh alignment
brakes
all oem
wheels
Currently on car:
Rota Group N
15x7
Included in trade:
Work Miester S1
2 piece
17x8 38mm offset
chino239
Dec 7, 2011 04:40 PM
n1_egsex
Dec 13, 2007 08:55 PM
