Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
2002 Honda Civic Alternator Fuse Keeps Blowing
Old Nov 20, 2011 | 04:42 PM
Master23's Avatar
Default 2002 Honda Civic Alternator Fuse Keeps Blowing
The battery has been replaced. I took in my alternator to have it tested which it came out bad so I replaced it as well.
I put in a new fuse and it blows immediately when the engine is cranked.
I looked everywhere for a short or a wire rubbing in the engine bay no luck.
Any ideas?
Old Nov 20, 2011 | 07:07 PM
eviee1973's Avatar
Default Re: 2002 Honda Civic Alternator Fuse Keeps Blowing
Possibly a dead short inside your "replacement" alternator. Is the proper alternator in the car, a poor quality rebuild, a junkyard special? Try another alternator to see if the alternator is tha cause of the dead short.
Old Nov 21, 2011 | 04:25 AM
GriFFIthS's Avatar
so the fuse was popping, you replaced both the battery and the alternator and its still popping?
unplug your o2 sensors and replace the fuse and try it then, if it doesnt pop, its a short in one of the o2 sensors, I have a short in my secondary and it would pop the fuse for the alternator, force my car to run off the battery and eventually ran it down.
Old Nov 21, 2011 | 09:21 AM
Master23's Avatar
The funny thing is I had isolated the alternator by removing the plugs and started up the car and still the fuse popped (no I didn't remove the alternator plug while the car was running). I'll have to check the O2 sensor next.
youngturbo
Aug 10, 2010 06:28 PM
lmike6453
Jan 16, 2009 06:55 PM
ge_itr
Aug 26, 2006 12:42 AM
IHTFP
Aug 16, 2006 08:00 PM
