oem dc2 rear wiper delete
The Integra, on the other hand, was sold by Honda's Acura marketing arm as a low-end luxury model with sporting pretensions. Rear-wiper deletion would definitely NOT have fit with Acura's marketing image.
But there's nothing to prevent you from re-purposing parts from some other origin as your wiper-delete. All you really need to do is plug that hole in the glass. I can even see using a blanker-plug from a plumbing-supply place, maybe with a shot of matte-lack paint, or a bit of black 3M ScotchCal film over the chrome.
the civic fits in the integra. theres a rubber and a metal one they both fit
edit: heres the write up. gives you the step by step and part numbers.
http://www.team-integra.net/forum/bl...er-delete.html
I used the one from a 92-95 Civic hatch. Fits perfectly on my Integra.
90301-SR3-000 NUT, RR. WIPER MOTOR PIVOT (6MM)
93402-06012-00 BOLT-WASHER (6X12)
Once you get your parts, you need a washer large enough so it doesn't slip through the Integra grommet (in the hatch glass).
Reach inside your engine bay behind your battery. There is a round plug that perfectly fits the rear wiper. Thats what I used
Otherwise, go to the junkyard, look underneath the battery tray. A plug should be there (unless an aftermarket deck was installed and they ran sub wires). I used that and didnt even silicone it. No leaks, fits perfectly. People should know this by now hahaha
Op why don't you reach in your engine bay and use the firewall plug. Its the same part number as the one above from honda. And they DID COME Stock. Integra type R year 2000 color Papaya doesn't come with a REAR WIPER!
EDIT: or go to junkyard and buy one for 1$
LOL, $12.99 for a dummy plug.
As mentioned, go to your local bone yard and pick one up, our local PicknPull does not even charge for dummy plugs if you get anything else. 94
thadon805
Feb 14, 2017 07:56 PM
MrHeeltoe
43
Dec 21, 2005 07:46 AM
