91 Accord Rocker Panel Removal
Old Oct 7, 2002 | 07:14 AM
Joe 91 Accord's Avatar
Default 91 Accord Rocker Panel Removal
I am having trouble removing the rocker panel cover.....the clips do not seem to be releasing as I am pulling on the cover. I am trying to clean up some rust under the cover and I need to remove them. Has anyone removed the covers, if so how? Any help or suggestions is appreciated. Joe
Old Oct 7, 2002 | 07:36 AM
Nick M's Avatar
Default Re: 91 Accord Rocker Panel Removal (Joe 91 Accord)
Just pull on them with your hands alittle more than shoulder width apart. Dont be afraid of the rocker panel.
Old Oct 7, 2002 | 07:41 AM
Default Re: 91 Accord Rocker Panel Removal (Nick M)
I tried pulling on them and broke one of the clips, that is why I thought that maybe there was a trick to remove them.
Old Oct 7, 2002 | 07:51 AM
Nick M's Avatar
When doing new car prep work at Honda I had to frequently remove them. I dont know how you could break a clip. The white plastic clips are available from Honda. Unless you broke the piece on the rocker panel itself. I pull them from the inside towards me. Thats the best advice I can give you.
Old Oct 7, 2002 | 08:01 AM
I didn't break the panel, rather the white plastic clip. The panel snaps into the rocker and wraps around to the underside of the car, where it is attached by snap-in fasteners. I am not sure what you meant by grabbing it from the inside and pulling? When you grab it from the bottom and try to pull, it tends twist and not put correct pressure for removal. Thanks again for your help and replies.
Old Oct 7, 2002 | 08:21 AM
RUBZERK's Avatar
pry up with a flat screwdriver next to the clip
onda22
Aug 28, 2011 08:07 AM
Dkahn18
Jan 3, 2009 09:18 AM
yomayo
Nov 22, 2006 05:11 PM
ArthurBrazil
Oct 10, 2006 12:03 PM
Protoss
Mar 9, 2006 04:42 PM
