Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Sorting out the new "toy" opinions, please.
Old Oct 7, 2002 | 07:00 AM
BryanSprinkel's Avatar
Default Sorting out the new "toy" opinions, please.
Ok, I have been trying to get a few things together for this weekend at VIR. I would some opinions on a few things.
The car: 2000 Civic hatch.
1st: Front sway bar.
I am using KYB AGX's with rates of 340 front, and 450 rear. 2000 civic SI susp'n front and rear, including the 12-13mm rear sway. I have a GSR stock front sway, should I install this?
2nd: 98 GSR MC, and brake booster.
The car is using GSR front and rear calipers and rotors. I am trying to locate a set of panther plus pads for the front. I am using some Endless pads on the rear (these were on the car when I got it). Is it worth it to swap to the GSR MC <U>and</U> booster. I already have both of these parts.
3rd alignment settings
What toe settings should I use? "0" front and rear was recommended, just wanted some insight. I will be running street tires.
4th Oil Pan swap
The car currently has a Moroso 5 qt "drag racing" oil pan. Should I worry about this at VIR? I think I can locate a stock oil pan, but should I even bother?
I think that is everything. Thanks in advance for the input.
Old Oct 7, 2002 | 07:12 AM
Crack Monkey's Avatar
Default Re: Sorting out the new "toy" opinions, please. (BryanSprinkel)
Yes, install it. You don't have enough spring to run without.
No idea. How does the pedal feel? If it feels firm and doesn't have excessive travel, I wouldn't do it until you have time to try it on the street.
0 toe is a good start. Most people end up running slight toe out up front to aid turn-in.
4th Oil Pan swap
No clue. How low is it? If it work son the street (with potholes and speed bumps and such), it should be ok for the track. More oil is good.
Old Oct 7, 2002 | 09:42 AM
Default Re: Sorting out the new "toy" opinions, please. (Crack Monkey)
Thanks Alistair,
How would just using the MC with the stock civic booster work?
thanks
Old Oct 7, 2002 | 09:50 AM
B18CXr's Avatar
set it on fire, after you let me drive it
Old Oct 7, 2002 | 09:52 AM
Default Re: Sorting out the new "toy" opinions, please. (B18CXr)
Tempting, but no..
Why would you want to drive a "stock" 00 Civic DX?
Old Oct 7, 2002 | 10:07 AM
Johnny Tran's Avatar
exactly my point.......civics suck. sell it to a ricer like robert, or trade him for a real car like a 69 camaro
Old Oct 7, 2002 | 10:21 AM
Willard's Avatar
4th Oil Pan swap
find a stock pan and bring it with you.
watch the oil light at #3, #4, and the left hander on the crossover and see if it comes on.
I think you 'may' have issues.
Old Oct 7, 2002 | 12:40 PM
Doctor CorteZ's Avatar
front bar - NO plenty of people run soft rates and stock front bar or NO front bar , I wouldnt put it on
MC - it wont fit on the civic booster , I wouldnt sweat it. pedal goes a LITTLE too far but no biggie
toe - 1/16" toe out on each side front did very nice for me , a big difference over the old settings.
oil pan - not sure , but I dont like drag racing parts so I agree with Willie on that one.
Old Oct 7, 2002 | 04:00 PM
Thanks for the replies.
I have an oil pan I will be putting on tomorrow. (thanks Ben)
I will attempt to install the GSR MC and booster tomorrow, then adding ATE super blue.
Front bar will go on to see how she feels.
Still deciding on the alignment settings.
Thanks again
Old Oct 8, 2002 | 10:32 AM
good deal man
RajaNiche
Feb 27, 2006 07:42 PM
C-speed
49
Jul 18, 2005 04:08 PM
EVOLMTR
Feb 13, 2005 11:11 PM
JDMTurboCivic11
Jan 25, 2005 07:06 PM
JeffS
11
May 13, 2002 09:46 AM
