95 Accord Cold Start Smoking
Old Nov 20, 2011 | 04:57 AM
Suma's Avatar
Default 95 Accord Cold Start Smoking
1995 accord seems to smoke (white) on start only when the temp is below 35(outside temp) or so. Smokes up to 5 minutes if idling but goes away and no issues while warm.
Some crazy sensor maybe?
95 Accord Ex 4Cyl
Old Nov 20, 2011 | 06:22 AM
onefootinhell's Avatar
Default Re: 95 Accord Cold Start Smoking
valve seals? just a guess
Old Nov 21, 2011 | 07:45 PM
seanbev24's Avatar
Perfectly normal for a car to smoke on start-up when it's cold out. If it goes away after a few minutes, don't worry about it.
Old Nov 21, 2011 | 08:14 PM
oneprblmcat's Avatar
If the smoke is white and it rises and dissipates then this is steam created by the warm exhuast gases and air flowing through the cold exhaust pipe. As the exhaust tubing warms it becomes less noticeable. Same reason water will sometimes drip from the tail pipe. Completely normal.
If the smoke is a puffy white and does not dissipate, this is transmissiont fluid entering the combustion chamber and being burned and mixed in with the exhaust gases. Not normal but I don't think it's likely with our Hondas. Vehicles that used a vacuum operated transmission modulator can have this issue.
Hope this helps
Old Nov 21, 2011 | 08:23 PM
blkej6's Avatar
are you losing any fluids?
Old Nov 21, 2011 | 08:39 PM
HonBeer's Avatar
If it's white. It is not oil. Oil burning at start up is blue. Sounds like steam to me. Hence leaking coolant into the combustion chamber via bad head gasket.
db8int3gra
Feb 11, 2009 10:07 AM
jay2415
Dec 12, 2008 10:50 AM
Bruce Banner
Feb 16, 2007 05:59 PM
Officer
Dec 25, 2005 06:03 PM
TheOnlyDRAGooN
Dec 22, 2005 04:35 AM
