97 del sol 1.6L SOHC - Misfire
Old Nov 19, 2011 | 12:50 PM
del-sol-timr's Avatar
Default 97 del sol 1.6L SOHC - Misfire
I have a 97 del sol SOHC. The other day it was running fine and 3 minutes from my house while climbing a hill at interstate speeds, the engine began to misfire and the CEL began flashing. I made it back to my house with limited power and continual misfiring. At idle, it sounds like a baby muscle car. The initial CEL code was misfire in cylinders 1,2, and 4. After troubleshooting and removing the ground from battery; CEL code of only misfire in cylinder 2.
I checked fuel pressure between the fuel filter and fuel rail. Fuel pressure tested ok.
Running: 44psi
After off: 42psi
After 30 min bleed off: 38 psi
During this process I also removed ground from battery and decided to re-check CEL. CEL this time was misfire in all four cylinders. I proceeded to check spark plugs and wires. All checked out ok. I have good spark on all 4.
I visually inspected inside of distributor and everything also looked in good condition here.
Again removed ground from battery, ran the car, and re-checked CEL this time misfire in cylinder 1 and 2.
I did a cylinder drop test and dropping spark to cylinders 1 and two seem to have no affect on the engine.
The misfire codes are the only ones I am getting.
I plan to test the ICM next, but would love to hear some suggestions!
Thanks in advance!
Old Nov 20, 2011 | 05:27 PM
Resurrected_EJ's Avatar
Default Re: 97 del sol 1.6L SOHC - Misfire
ok anyone correct me if im off base here i dont claim to know everything but the ignitor in the distributor maybe??
Old Nov 20, 2011 | 05:37 PM
Former User's Avatar
How old are the plugs, wires, cap, and rotor?
You also should test both the coil and ICM.
Antibullllseye
Jul 23, 2016 02:56 PM
delslomt
Dec 28, 2012 01:03 PM
Wonko
Jun 12, 2011 05:48 PM
vtecrasr
Dec 6, 2009 08:20 PM
