97' Prelude SH - blew motor, F22b1 swap, confused and have questions.
Old Nov 19, 2011 | 06:30 AM
Ek9.civic's Avatar
Default 97' Prelude SH - blew motor, F22b1 swap, confused and have questions.
I'm currently in a bind due to my engine giving out just recently and I don't have the money right now to purchase a replacement H22. Luckily, I have a F22b1 sitting in my shed. I have decided to quickly drop that in so I can have a car to drive to work. I've been running into a few issues and I hope you guys and help me out.
Shell - OBD2 97' Prelude SH
ECU- P5P (willing to buy OBD2 F22b1 96-97 Accord Vtec if need to. Need to pass vehicle inspection.)
Harness - OBD2 97' Prelude SH harness
Engine - OBD1 F22b1 (can't find TDC/CKP sensors by the crank pulley. Assuming it's OBD1)
After research, I am aware that the OBD2 ecu will be searching for the sensors by the crank. The last thing I would want to do is replace the oil pump with an OBD2 pump w/sensors. Is there any way around that? I'm in the process of purchasing a new distributor(confused if it's best to buy one with external coil or internal coil), ecu(if need to), etc. Be aware that I don't have a lot of funds to work with and that I am willing to do wiring if need to. Thanks
Old Nov 19, 2011 | 06:35 AM
InvaderTrax's Avatar
Default Re: 97' Prelude SH - blew motor, F22b1 swap, confused and have questions.
Don't forget you'll need a base/Accord transmission
Old Nov 19, 2011 | 06:45 AM
Ek9.civic's Avatar
Thanks for looking out. I have bolted on a F22b1 5-speed transmission, Prelude Intermediate shaft, and Prelude axles.
AccordBOB381
Sep 15, 2014 09:29 PM
Flabah
Jun 7, 2008 09:05 AM
97LXF20B
Nov 1, 2007 09:03 AM
duceducecord
Jul 1, 2006 09:27 AM
kotetu
May 16, 2003 04:04 AM
