Classic Hondas All Pre-1988 Hondas.
EF B20 Wont Crank Over - Injectors no Power
Old Nov 18, 2011 | 11:59 PM
velasquezgenaro's Avatar
Default EF B20 Wont Crank Over - Injectors no Power
I have a honda civic ef 1988 obd0 with a swapped b20 and converted it to obd1. I have a pr3 ecu obd2b distributor and obd1 injectors. The car cranks but doesnt turn over. I checked the fuel pump and it primes, main relay works, the injectors work. I took off the resistor box cause I dont need it for the obd1. I double checked all wiring and everything looks fine. Im not getting any power from the ecu to the injectors. Im stuck and have no ideas as to what else to do. Any help would be much appreciated.
Old Nov 19, 2011 | 12:04 AM
rickyracer's Avatar
Default Re: EF B20 Wont Crank Over - Injectors no Power
how do you no if the injectors work?
Old Nov 19, 2011 | 12:38 AM
I put them straight to the battery an they sprayed an the car turned on while the fuel lasted so there OK I guess but a friend just gave me two other sets of injects an I'm ganna try those...but my problem is no power coming from the ecu
Old Nov 19, 2011 | 07:00 AM
Stretch7's Avatar
You'd get better help in the correct section, my friend.
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/
Old Nov 19, 2011 | 07:49 AM
I'm new at this site I just made it lastnight....
da9blk1
Oct 1, 2012 02:00 PM
ironman85
14
Oct 30, 2010 03:02 PM
SCerbanger
Jun 23, 2010 04:59 PM
gonmaro
Apr 1, 2009 07:14 PM
Deetz
Sep 17, 2003 05:11 PM
