91 Lx sedan Help!
I have a 91 lx sedan with b18 swap. Well i pulled the ls out to put in my crx then i blew the dif out of the tranny. So i put the ls back into the four door. Now it miss fireing.. I redid the previous owners Dpfi to Mpfi I have no check engin lights its just miss firing my car sounds like a four wheeler lol.. Any ideas? Car is in time all my grounds are good. Im not sure what it could be
Iv checked all the connections i dont really have none lose or anything. Like i said i redid all the wires everything is shrink wraped and tight. ill try another dizzy
going to get plugs and wires now.. With my wireing.. I lets the car run and wiggled all my wires and conectors and **** to see if it would get better or worse and it never changes.
Well i stuck plugs and wires on today did nothing.. Changed out the Ect enging colant temp cuz i read that will make your car miss fire. I changed that and it ran fine a little hesataion but after 2grand it would be fine. I took it for a little drive. Got it back to the garge shut it off. Went to start it again Doing it again! think the dizzy is going out?
i know that it sounds stupid, but make sure the firing order is correct. if you have 2 flippid it will still run, just miss very badly
also make sure your engine grounds are all clean, your motor cannot ground the rubber mounts.
then after that, yes starting taking off plug wires one by one
Can someone help please this is the problem i'm having i have a 88 ef sedan lx i just converted to mpfi and obd1 I have checked my wiring and can't figure out my problem it seams to run decent at low RPM's around 3k. But if i get over that it starts like falling on its face like stops pulling it backfires and shuts off I'm throwing a code 4, code 7, code 9, and code 15. I've tried 2 new distributors and still does the same thing. Can someone please give me some idea's. Thanks for any help that I recieve.
Code 4 Crank position sensor
Code 7 Throttle position sensor
Code 9 No.1 cylinder position sensor
Code 15 Ignition output signal
dirtrider88
Feb 10, 2013 07:42 AM
Coltmorris
Jul 13, 2009 11:32 AM
graveltravel2
Jan 1, 2009 03:15 PM
