FS: K and B All motor Race short blocks
FS:
Selling our back up short block from last season. Was never actually ran this season. The short block has no run time since reassembly after tear down and inspection and only had a hand full of dyno and track passes the first time it was assembled. Went a 10.52@131 on this short block.
We have been hanging on to it all season just in case, and luckily is was never needed so is for sale.
K24 103mm race short block. $4000
Golden Eagle 90mm sleeves
Drag Cartel 103mm crank
Drag Cartel JE Pistons
Drag Cartel Rods
Assembled with ACL Race bearings
Next is almost everything to put together an all motor B-series shortblock. I will sell it all for $2000
Golden Eagle Sleeved B18a1 Block. Bored and honed to 86.5mm $1000
Brand New Custom CP 86.5mm 12.5:1 B series pistons. They have been prepped so all the sharp edges are removed $650
Crower Maxi-lite rods, LS rod length. Used but less than 100 miles on them $500
Moroso Steel B-Series Oil Pan 5.5qt. It is tapped and plugged for turbo drain line and oil temp sensors. $300
Drag Cartel Rods
edo
Sep 2, 2005 09:17 AM
