How to do 2000 front conversion??
Old Nov 18, 2011 | 10:26 AM
eksilver's Avatar
Default How to do 2000 front conversion??
I have a 98 civic and im doing the 2000 front conversion this week. I already got a OEM 2000 front i just dont know how to install it. What brackets do i need to bend or cut. Anyone got pictures or a diagram on how to do this conversion. thanks
Old Nov 18, 2011 | 10:30 AM
kaiba's Avatar
Default Re: How to do 2000 front conversion??
Sell the 98 civic and buy a 99-00 civic.
Old Nov 18, 2011 | 10:35 AM
jdmadam's Avatar
LoL, or just take it to the body shop.
Here you go--->https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/99-00-conversion-96-98-how-790135/
I found that and it took me a 1 min seach.
Old Nov 18, 2011 | 01:49 PM
apexi_rsx's Avatar
you need to drill out the old spot welds on the front rad support and pry it off and do the same to the 00 civic rad support. install it with bolts to hold it on and you can adjust it to make everything fit perfectly then weld it in. then install the hood ,headlights,and fenders.
Old Nov 18, 2011 | 02:25 PM
jdmadam's Avatar
That is the correct way to do it but that way is not necessary. You can make it work just by trimming a few brackets.
Old Nov 18, 2011 | 02:52 PM
Wrona's Avatar
remove old rad support get 99-00 rad suport weld it on bolt everything on.... if you would of searched you would find 500 threads about this
Old Nov 18, 2011 | 03:11 PM
MRGRIM's Avatar
R.I.P. Mark
you can just replace the top half of the rad support ..
makes an easyer job..
top support, center upright, and headlight suport frame ..
it joins the lower half acrosss the top of the chasssi rails
take off as one peice
Old Nov 18, 2011 | 09:50 PM
98civdx's Avatar
Master Detailer
The only thing you need to do to the core support is trim the bumper mount bracket, and re drill the hole we you want it. Anyone that tells you, you need to replace the core support does not know what they're talking about.
Everything else bolts on.
Old Nov 19, 2011 | 04:35 AM
southie's civic's Avatar
Just did this on myn u throw away the foam its useless, then hammer in the four corners of the bumper support it has to be flat instead of the lil metal lips from how they made it , the radiator support takes time but line the bumper up where it sorta comes in on the ends of where the grille goes and just hammer the suppport so it curves in more test fit the bumper alot , i put the new fenders and hood on to help get my lines right then the last few test fits have the headlights in just so everything is good ,, use spray paint on the suppports after to cover up the hammer marks i used high temp spray paint it goes on heavier than normal spray paint and fills the marks in ,, good luck its not hard just takes alot of work to get right pm me if u want ill txt u pics
NOFX
67
Feb 1, 2012 07:06 AM
2gturboteg
Nov 7, 2005 04:23 AM
