Installed Prelude cluster into 95 accord...ABS light???
Old Nov 18, 2011 | 05:59 AM
deagleEF8's Avatar
Default Installed Prelude cluster into 95 accord...ABS light???
Installed a prelude cluster into a 95 accord ex AUTO the other day. Install was fine, wired everything up as per how-to, quadruple checked all the wires, made sure everything is in check. Everything works, except the ABS LIGHT goes on. Light goes on after the car is started, maybe a second or two after. Stays on, does not go away. I just had the abs services prior to installing the cluster. Meaning I bled the ABS mod, checked the abs wheel sensors, bled the brakes, checked the fuses etc. I checked for any codes via SCS PLUG under the glove box. No codes.
Im thinking its a power issue because when im driving, the abs light dims intermittently. I checked the charging system for kicks, everything is good.
Really stumped on this one. Can anybody shed some light?
Thanks
Old Nov 18, 2011 | 06:41 AM
TheMuffinMan's Avatar
He knows where you live!
Default Re: Installed Prelude cluster into 95 accord...ABS light???
What year Prelude cluster?
Does ABS work?
Old Nov 18, 2011 | 02:07 PM
deagleEF8's Avatar
01 prelude. Drove the car again today. Dimming is more prominent when driving during the day. What is odd is that when i was driving at night, the abs light does not dim when the cluster lights/headlights are on. Its solid yellow.
Here is a pic of it at idle:
stangman39
Oct 14, 2008 06:33 PM
EM199dcs
Jan 25, 2007 10:58 AM
JimmyAtlantis
Dec 8, 2005 08:51 AM
Beezle
May 24, 2005 10:01 PM
Prod
Nov 4, 2004 03:09 PM
