ls or gsr crank need help
what up guys so im building a turbo set up and i have a gsr block b16 head
so i have eagle rods and they dont fit my gsr crank because they are for ls/b20
i dont know what to do
i was told to just drop my crank go ls crank and just be "stroked" and it will make more power and more torque
and its cheaper then buying new gsr eagle rods
what do u guys think i should do?
goal is 325- 350whp
all replies appreciated thanks guys
goal is 325- 350whp
This Is the setup i had in my last integra. The LS crank adds a bit more stroke to the motor, and increases the displacement roughly 40cc.
Granted, I had a 2.0 sleeved motor, but it included CP pistons and LS length Manley rods paired up with a micro polished LS crank/ OEM bearings inside of a GSR block.
It adds a bit more torque due to the increase in the stroke but not much. It is a drop in mod as long as you have the LS sized rods, which you do.
You'll be ok. And if the motor is completely stock, including compression, then you should have no problem breaking 300whp.
Good luck to you
Good luck to you
thanks for the reply
motor isnt stock i have pistons etc
just i have the eagle h beams and dont wanna spend another 3xx on new ones when i can spend 100 on a crank and another 50 or so on new bearings for that crank
what is the razor edge crank do? like when they edge it to be sharp is that good or bad on a daily driver boost
Knife-edging is a process that a machine shop will do to a crank that will basically remove a lot of material from the crank counterweights, which are the large cast portions of the crank that connect the main bearing journals to the rod bearing journals. They will remove the material at an angle and the result looks similar to a knife's edge, hence the term. The overall result is the crank has less weight, so it will spin faster easier (but also lose revs faster) and the 'knife-edge' will also cut through the air and oil easier, in effect reducing the parasitic drag from these variables.
For a daily driver, it's not worth it.
change of plans :} so came across some gsr eagle rods for 300 and i sold my type r pistons for 250 the same day so i just did 50 out of my pocket and got mmy rods so looks like im sticking with the gsr crank :}
