97-01 Honda Prelude B&G Lowering springs! Brand NEW!!
I have a brand new set of B&G lowering springs for sale. Looking to get 185 shipped. Information is below on the drop and details.
Features
Improve handling while maintaining safety and ride quality
Lower your ride’s center of gravity .5-2.5”, depending on your vehicle
Get the sleek, low-to-the-ground appearance you’re after
Progressive rate design adapts to your driving environment
Individually super-blocked and computer-tested against tight tolerances
Cold-wound from high tensile chromium silicone wire
Heat-treated and shot-peened for longevity
Phosphate treated and resin-baked for a hard corrosion-resistant shell
Includes all 4 springs
Limited Lifetime Warranty
Description
Created for the true performance enthusiast, B&G S2 Sport Springs improve handling and substantially lower your ride. Drop your center of gravity up to 2.5”, depending on your vehicle, and corner like you’re on rails with these progressive-rate springs.
B&G crafts their S2 Sport Springs with the highest attention to detail. First, these springs are cold-wound from high tensile chromium silicone wire. Then, they’re heat-treated and shot-peened for supreme longevity. Finally, B&G finishes with a phosphate treatment and bakes these springs on resin powder coating for a hard shell that resists corrosion.
What’s more, B&G S2 Sport Springs are individually super-blocked and computer-tested against tight tolerances so you get the best quality every time. Includes all 4 springs. Lifetime Warranty.
Features
Description
