Swapping A B20 Into a 92 Hatch
Old Oct 7, 2002 | 03:07 AM
The G2 Racer's Avatar
Default Swapping A B20 Into a 92 Hatch
I've done a search and couldn't find anything that really helped me. So I'm asking this question. What parts do I need to swap a b20 into my 92 DX hatch. I know I need the LS intake manifold but what about mounts do any of them need to be changed? Alternator? Distribuator? What parts need to be changed to get this engine in?
Do I have to install b-series fuel lines or will my d-series fit and give the engine enough fuel?
Thanks in advance for any and all help
Old Oct 7, 2002 | 07:01 AM
Default Re: Swapping A B20 Into a 92 Hatch (The G2 Racer)
bump
Old Oct 7, 2002 | 07:26 AM
Plan B's Avatar
92-95 ls ecu
obd1 ls intake manifold
b-series exhaust manifold
timing mount bracket from 94-00 integra
rear mount brakcet from 94 - 00 integra
b-series axles and midshaft
flywheel
clutch
transmission
integra throttle cable
b-series fuel line
b20 dist works fine, so does alternator and injectors, but you will have to rewire these for obd1 unless you have obd1 parts to replace them with.
I just finished a b20 swap into a 98 dx hatch last night. It's fast.
edit: a/c bracket from 94-95 del sol vtec. in order to retain A/c properly.
[Modified by Plan B, 11:27 AM 10/7/2002]
Old Oct 7, 2002 | 07:28 AM
94EG6HB's Avatar
I have a list somewheres...
I'll PM it too you...
[Modified by 94EG6HB, 11:29 AM 10/7/2002]
Old Oct 7, 2002 | 07:35 AM
Default Re: Swapping A B20 Into a 92 Hatch (94EG6HB)
Thanks guys. I don't have A/C in my hatch so no problems there.
Old Oct 15, 2002 | 03:12 PM
Since I want to turbo this engine. Would an LS or jdm GS-R tranny be best?
Old Oct 15, 2002 | 03:20 PM
95hbMatt's Avatar
go with the LS tranny...longer gears which lets the turbo spool longer...gsr tranny has short gears and is not good for turbo...
Old Oct 15, 2002 | 03:57 PM
lazy bum shaughn's Avatar
Just curious, how much are you getting your block from, and where at?
Thanks.
Old Oct 15, 2002 | 06:28 PM
phillycx's Avatar
I am also interested in this swap. Looking to put it into my 2000 dx auto and i'm keeping it auto. Could you send me that list too. Thanks!
Old Oct 15, 2002 | 06:34 PM
Plan B's Avatar
Default Re: Swapping A B20 Into a 92 Hatch (phillydx)
Whoa! Auto, Yike yo
Check the list above and keep dreamin on the Auto swap
Old Oct 15, 2002 | 06:37 PM
Default Re: Swapping A B20 Into a 92 Hatch (Breakdancer)
Thanks.
I'm getitng it from a friend of mine.
JesterDKing
Mar 16, 2013 04:42 PM
95EG2
Dec 13, 2009 02:58 PM
CompanyFlow
Feb 6, 2005 03:31 PM
spider_man02
Mar 25, 2003 11:58 AM
rocket_R
May 14, 2002 04:20 AM
