Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
my es1 build
Old Nov 17, 2011 | 05:58 AM
rustyferio's Avatar
Default my es1 build
XXX
Old Nov 18, 2011 | 07:44 AM
rustyferio's Avatar
Default Re: my dopeblue es1 build
XXX
Old Nov 18, 2011 | 05:05 PM
FonzoB5S4's Avatar
nice. that velocity stack is ridiculous!
Old Nov 21, 2011 | 04:39 AM
rustyferio's Avatar
XXX
Old Nov 21, 2011 | 06:37 AM
rustyferio's Avatar
XXX
Old Nov 21, 2011 | 06:40 AM
Drewskii's Avatar
can you get ahold of some for guards for me? too pricey at honda here haha
Old Nov 21, 2011 | 06:44 AM
speedooo's Avatar
Put a filter back on.
Old Nov 21, 2011 | 07:59 AM
rustyferio's Avatar
XXX
Old Nov 21, 2011 | 09:41 AM
speedooo's Avatar
Oh jeez lol 17.1? You need a swap!
Old Nov 21, 2011 | 01:18 PM
rustyferio's Avatar
XXX
Old Nov 21, 2011 | 01:52 PM
94IntegraRS's Avatar
What engine does these come stock with? Also I really like them blue lug nuts lol, I might have to get a set of red ones for my Integra. Great build, can't wait to see more updates.
Old Nov 21, 2011 | 05:52 PM
rustyferio's Avatar
XXX
Old Nov 21, 2011 | 06:19 PM
rustyferio's Avatar
XXX
Old Nov 22, 2011 | 12:51 PM
Originally Posted by rustyferio
Thanx man, these come with a sohc 1.7, mine is non vtec, the si has a k20 which Is the swap I wanna do.
Thanks for the info. That'd be sweet when you do the swap lol. Also I had a question on the blox velocity stack, what is this for and what does it do? I am just curious, because I have never seen anything like that before.
Old Nov 22, 2011 | 12:57 PM
speedooo's Avatar
You want the 06+ Si K20, the 01-05 Si has the k20a3 turd.
Old Nov 22, 2011 | 01:01 PM
toyomatt84's Avatar
Sanji
A K20A3 is still an improvement on the D17, I can assure you.
Old Nov 22, 2011 | 04:24 PM
rustyferio's Avatar
Its goes on intake piping and it for more air flow, i seen a lot of turbo cars running these on the track and on individual throttle body motors.
http://en.m.wikipedia.org/wiki/Velocity_stack
This explains in more detail
im dumb cause I should of kept my 01 coupe cause i had a complete swap out of a 08 si that got wrecked, but I was stupid. I would like to have one of the first j swapped 7th gen but just a dream lol
Old Nov 22, 2011 | 05:24 PM
Awesome, Thanks for the link filled with info lol. Can't wait to the the visor and fogs installed
Old Nov 23, 2011 | 07:33 AM
rustyferio's Avatar
anytime, hopefully i have them installed this weekend, since i got the next 4 days off
Old Nov 24, 2011 | 05:48 AM
rustyferio's Avatar
XXX
Old Nov 24, 2011 | 10:50 AM
rustyferio's Avatar
xxx
Old Nov 24, 2011 | 03:26 PM
apexi_rsx's Avatar
you know u could have cleaned ur old headlights by wet sanding them and using a buffer on a drill and using rubbing compound or plast-x on them and cleared them right up for 20 bux instead of buying new headlights. usually running a velocity stack u should use your OEM drop in filter box so no debris enters ur motor. the way ur running it all kinds of dirt can enter the motor and scar ur cylinder walls. just alil food for thought.
Old Nov 24, 2011 | 03:34 PM
88CRX951's Avatar
I OLD SKOOL
IMO I would've left stock hubcaps on till you get wheels. But good progress...
Old Nov 24, 2011 | 07:40 PM
db1st's Avatar
the build looks like it's coming along well. Hopefully you are aware of this but, I wouldn't recommend using tapered/cone lug nuts on round (spherical) seated OEM wheel. Reason being, using the wrong style lug nuts can possibly strip both the threads on the studs and lug nuts itself because the lug nuts doesn't seat properly on the rims. Also, you can easily dis-figure the tip of the lug nuts when torquing them on. IMO, i would hold off on the aftermarket lug nuts till i get some aftermarket rims with tapered lug openings.
Old Nov 24, 2011 | 08:40 PM
dj_lujan's Avatar
Good stuff and nice build.
