FS/FT 92-95 Civic EX/SI Mint Rare Door Panals&More
Whats Up H-T I Just Parted Out my 95 Civic Ex And i Got Some Parts Left From it..That was Saving Because there Hard to Find...Ill throw Some Other Parts Into Sell....Check my Other Threads For Alot of Good Parts
Name:Zack Location:Smithfield,Pa,15478 Phone:724-984-2168
(None of Prices Include Shipping....PAYPAL IS Ready At Anytime
I Have A List of Parts Im Looking for at Bottom of list check it out ill trade for the stuff i need
1.92-95 Civic Coupe EX/SI Mint Black Door Panals/With Acoustic Research Tweeters...Both Sides Are Really Mint...Only Have Picture of Driver Side..But Passenger Side is More mint then Driver....I Seen these Go on here&Ebay for Over $250.00 (Sry About Picture #2 I just found this pic and u can kinda see Panal
Asking $150.00+Shipping
2.92-95 Civic Coupe EX/SI Acoustic Research Rear Speaker Pods L+R And BOTH Rear Speaker Covers(They Look Super Mint And Clean Covering Speaker...One Has Small Split...But you Get Both Speaker Pods to Hold Speakers And that The Speaker Grills Bolt to...$50.00 Shipped For Pods/Covers (SRY DONT HAVE PICTURE AT THE MOMENT)
3.INTEGRA GSR Tan Leather Front Seats....Driver Side is Ruff...But Passenger is Good u can Get Refurbished And Make them Black....$125.00 Picked up or U Pay shipping
4.92-95 Civic Ex/Si SunRoof/Dimmer/Cruise Switch $20.00 Shipped
92-95 Civic Ex/Si Defrost Switch $10.00 Shipped
Main Relay $22.50 Shipped ///Integra Rack Knuckle(so u can run a Integra Rack in ur Civic(Because Civic Knuckle is to small) $15.00 Shipped
Integra SunRoof Switch(Lil Black One) $13.00 Shipped
5.JackSon Racing Supercharger Menthol Injector Relay Switch $45.00 Shipped
K20 Map Sensor/Pigtail $45.00 Shipped
Civic OEM Map Sensor $37.50 Shipped
6.Integra Map Light $15.00 Shipped////OEM Civic Fuel Pumps 1 Has under 15k Miles on it...I dont keep Pumps that Have over 50k Mile...$50.00 Shipped Each (For whole Assembly..Pump/Screen/Mount!!!!!
88-91 Civic OEM Rear View Mirror....$15.00 Shipped
92-95 Civic Rear Gas Door $10.00 Shipped
92-95 Civic Rear Fuel Pump Cover for under back seat $10.00 shipped
7.B18C1/B16 OBD1 Knock Sensor...Round Plug...46k Miles $45.00 Shipped
8.Duel Crank Sensor/TDC Sensor...Im pretty sure its either off a F22 OR F20C ...$35.00 Shipped
9.DOHC ZC Axles&Half Shaft...Axle Ends Were takin Off to try to switch to work for sohc trans Since Zc tranny Went out....But boots arnt ripped&i Put the Axles Back Together...They Just Need Them Metal Bands....$125.00 Shipped For Both Axles&Half Shaft...These were in a 88-91 CRX If that helps
10.1992-2000 Civic Hydro Clutch Pedal &EK Clutch Line...$35.00 Shipped Each or Both for $60 Shipped
11.92-95 Civic Dash Cover...Great Shape$20.00 shipped///92-95 Civic CliMate Control Unit $45.00 shipped
12.D-SERIES MAIN SHAFT...NO GROUND DOWN GEARS $40.00 SHIPPED
13.RYWIRE OBD2 Dizzy to OBD1 Harness $27.00 Shipped
14.OBD0 RED Injector Plugs Off a Older Accord...Hard to find Red Ones...But will work for civics and others $15.00 shipped
15.D16Z6 Semi-Complete Head...Includes Vtec Solenoid/Valveer/All top Valve Train/LMA..CAM(Im 85% Sure this Cam is The Stage 2 Comp Cam i had layin around its got arrows and stuff on it....Head does not include Valves/Springs/retainers,,,,Great Head For Building...$85.00 Shipped
16.THIS PICTURE IS ALL FOR BEST OFFER DONT FEEL LIKE LISTING IT ALL
17.Nitrous Brand...7 Color...0-30 Psi Vaccum Gauge Only Not Boost $10.00 Shipped
18...White Ones Are SOHC Timing Covers $30.00 Shipped Each Sohc top and Bottom Set....$40.00 shied Each for B-Series Set
19.92-95 Civic DX Steel Mount $25.00 Shipped////92-95 Civic Ex Aluminum Mount $40.00 Shipped
20.92-95 Civic Ex Rear Wing....Has 2 Broken Bolts Where u Mount it...But pretty good Shape $40.00 +Shipping
21.(2)D16Y7 OBD2A ECUS...1 IS AUTO 1 IS MANUEL $32.50 Shipped for AUTO $42.50 Shipped for Manuel
22D16Y8 Manuel P2P Ecu...$65.00 Shipped
23.D15B8 OBD1 Manuel D15B8 Non Vtec Ecu...P05...$60.00 Shipped
24.OBD1 P07 Manuel ECU...Damaged...Has 1 Burnt Resistor...$25 hipped
25.D15B7/B8 OBD1 Distributor...Has low Mile Dizzy Cap/Button $45.00 Shipped
26.d16y8 OBD2 ALTINATOR $45.00 Shipped
27.D16Z6 OBD1 Altinator...No Pulley $32.00 Shipped
28.96-98 Civic Driver Side Head Light....No Broken Tabs....$35.00 Shipped
29B18A1 Valve Pan Cover $42.50 shipped
30.F22 Non Vtec Valve Cover $30.00 shipped
31.Old School Accord Shift **** with the Big White Numbers $12.00 Shipped
32.B-SERIES HYDRO Pressure Plate...Brand New...Im sure its Exedy stage 1...$65.00 shipped
33.B18A1 OBD0 BARE INTAKE MANIFOLD $25.00 SHIPPED
34.b16/b20/b18c sQAURE Plug Knock Sensor...Brand new $75.00 shipped
35.Injector Resistor Box....Plug Was Cut off to Wire in $22.50 shipped
36.D16Y8 CRANK/TDC Sensor $35.00 shipped
37.92-95 Civic EX/SI Power Mirrors...L+R ....$50.00 SHIPPED FOR BOTH
38.88-91 Civic Brown Glove Box $20.00 shipped////96-98 CIVIC TAN GLOVE BOX $35.00 SHIPPED
39.88-91 CIVIC Passenger Side Head Light Glass...$15.00 Shipped
40.92-95 Civic Cruise Control Unit $30.00 Shipped Each
41.92-95 CIVIC EX/SI Black Dash....Great Condition...No cluster or Glove Box....Hass Passenger Side Air Bag/Climate Control Unit $125.00 Picked up
42.Delsol Dash Switchs...Hazard/Defrost and Other..Work Perfect Just Faded...$20.00 Shipped takes all 3
43.B16A JDM OBD0 Throttle Body...Its offical had jdm writeing on bottom $60.00 Shipped
PARTS IM LOOKING FOR
92-95 Civic Hatchback...Carbon Fiber Duck Bill Wing..
B-Series Vtec SoleNoid
31x8 or 10 x 2 or 3 Front MouNT Intercooler(Nothin Crazy expensive
Rear Hatch Struts/Plugs to Screw them into
AEM UEGO Wideband
Eagle H-Beam Rods for LS
b18c5 type r Pistons... .20 over pistons
B-SERIES VTEC Valve Cover
B-SERIES 5 Speed STARTER
AEM UEGO Wideband
BADGUYNY
Sep 7, 2003 08:58 PM
