Adapter fitting for ABS delete
Old Nov 16, 2011 | 08:38 PM
tam4511's Avatar
Default Adapter fitting for ABS delete
Well i recently deleted my ABS and prior to, i did a lot of research and read that you could use the ABS MC but had to cut the line but a larger fitting on it (M12) and re flare it, or you can get a non-ABS MC.
Well i found a inverted flared adapter fitting that converts the 10mm non abs brake line to the 12mm abs MC, you just have to bend the line a little bit. Ive seen a lot for people searching for this with no answers and it took me a while to find it, just thought id share it with you guys.
PN: BQ43
https://www.brakequipstore.com/BQ43.html
EDIT: CAN A MOD MOVE THIS TO THE BRAKES SECTION?
Old Nov 18, 2011 | 11:38 AM
sc34dc4's Avatar
Default Re: Adapter fitting for ABS delete
This has been gone over a 100x in the custom engine bay thread. Also with part numbers for this adapter or M12x1.0 to 3an. Advance auto has adapters for $2 also. It's simple to just cut and re flare the 92-95 civic brake lines or integra rs lines. Takes 5 minutes.
Old Nov 22, 2011 | 06:19 AM
tam4511's Avatar
well i searched and took me a while to find them. Nothing showed up on HT or any other forum.
sjteg
Jul 25, 2009 07:21 PM
pinkspider
May 26, 2007 10:30 AM
BoostinEJ1
May 6, 2006 05:50 PM
