225/50/16 tire, any issues?
Old Nov 16, 2011 | 05:57 PM
gosu08's Avatar
Default 225/50/16 tire, any issues?
I currently have 215/45/16 on my 16x7 Spoons.
I found a set of cheap 225/50/16 Hoosier Drag Radials. This will fit on the rim fine and also will not rub during turns? I daily so rubbing is a factor.
I came across this picture and the person says it doesn't rub but am not sure of the wheel specs. My car is about the height of the one pictured.
If this is your car and you want me to take it down, please let me know
Old Nov 16, 2011 | 07:52 PM
Todd00's Avatar
I said I don't want a title!
Default Re: 225/50/16 tire, any issues?
Why do you want drag radials to drive daily?
And yes, that tire is waaay to big. Your speedo will be significantly off and I'd imagine you will rub.
That tire is also 1.5" taller than stock.
Old Nov 16, 2011 | 09:35 PM
ekcoupeh22's Avatar
That's a track tire go buy to black slipstreams and put the drags on there so when you wanna race put them on and it won't be noticeable!
Old Nov 17, 2011 | 12:57 PM
WheaMyRyceGo's Avatar
I wouldn't run a 225/50/16 if you are lowered.
I daily drive my ITR with Mickey Thompson Drag Radials 225/50/15 with no problems but I was on stock suspension. Those tires are the best mod I have done, other than doing the K24 swap!
Old Nov 22, 2011 | 08:56 PM
Tight-R's Avatar
^^ So your favorite mod was to ruin the way the car came? Very nice. Should have just bought a regular Integra.
Old Nov 24, 2011 | 02:25 PM
CW-ITR's Avatar
I belived and still do that all U.S. Acura dealers and U.S. law doesn't require that ITR buyers have to obligated to any "not to modify your ITR" contract. So, relax
Old Feb 20, 2020 | 11:54 AM
DonReyn's Avatar
5 Year Member
My Integra race car is on 225/50/R16 and it handles them very well. modifications must be made but I did not roll my fenders. I have zero rub.
Old Feb 21, 2020 | 04:47 AM
aw614's Avatar
10 Year Member
Loved
It isn't too tall of a tire that screws up with the gearing? I always thought a 23in tire was ideal for integras/civics
Old Feb 21, 2020 | 06:32 AM
itrdave's Avatar
6% longer gearing than stock - good if you want lower cruising rpm, but no good for acceleration...
Old Feb 23, 2020 | 04:29 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Only if you actually cruise at a lower indicated speed than before. Otherwise indicated speed and RPM will always be the same.
TravisBiggie
Feb 10, 2016 04:48 PM
PowerLeg
Nov 13, 2008 08:20 PM
Rhythm
Apr 7, 2006 12:04 PM
ScottEK
Mar 29, 2004 07:15 PM
ebelp
Feb 6, 2003 09:05 AM
