h22a2 prelude engine swap into 4th generation civic
Old Nov 16, 2011 | 01:11 PM
neil ripley's Avatar
Default h22a2 prelude engine swap into 4th generation civic
hi my friend has a prelude 2.3i that was set fire in an arsen attack, at his farm and the back end is ruined. but it still run and drives and would like to put the engine in a 4th gen civic how hard is this?
Old Nov 16, 2011 | 01:32 PM
4drEF's Avatar
Keyboard Humorist
Default Re: h22a2 prelude engine swap into 4th generation civic
H22A2 or H23A2?
You have 22 in your subject and 2.3i in the post.
Hasport makes a mount kit,b ut then you are left on your own to deal with the hydro clutch and shifter.
http://hasport.com/store/tech/efh1.pdf
Typical method for this engine into the EF is to use the H motor and a B-series trans.
H2B
You can Google that and see what is entailed.
The H trans is HUGE.
Old Nov 17, 2011 | 11:26 AM
its a 2.3 non vtec jf that helps any confusion thanks
preludeman87
Oct 31, 2005 06:43 PM
CBR
Oct 4, 2004 08:40 PM
Labrat
Nov 19, 2003 01:05 PM
Apocalypse
Feb 16, 2002 06:42 PM
