KSwap Info
Here you go:
First you will need to pick out a motor and transmission.
-motor
K20a Euro-R Accord
K24a2 - 04 05 (cable driven) 06-08 (drive by wire)
k24a4 - 03 05 (cable driven) 05 11 (drive by wire)
cable driven motors make the swap easier bc you dont have to swap throttle bodies.
-honda engine mount bracket-11910-PNA-000
-tranny 03-07 accord 5spd or 04-08 tsx 6spd (same year Euro-R 6spd)
-your choice of clutch and flywheel
-Intermediate shaft from 02-06 rsx typeS.
-Driveshaft shop kswap axles
-Hasport or Innovative( hybrid racing is suppost to be making a mount kit) mount kit 90-93 accord or 94-97 accord. ( if you have a Acura CL use the 94-97 accord mount kit).
-shifter and cables ( must match the transmission you are using. example: 03-07 accord 5spd= 03-07 accord shifter and cables.)
-you will need to make a custom shifter plate, the holes do not line up from any k series shifter.
-02-04 rsx type-S engine harness + you stock harness ( send them to hasport and they will do all the wiring for you, or you can buy the universal harness from hybrid racing and do a lil wiring )
-ecu, you can use the stock ecu ( will also need immobilizer bypass module or 02-04 rsx type-S ecu+Kpro ) ( i recommend Kpro, i was told by a AEM rep that Kpro is better)
-K swap header ( hybrid racing, private label, DC Sports, etc....)
-Rsx o2 sensor ( pre-cat )
-Karcepts AC/PS eliminator if you are not planning on using them, if you are you will need custom lines for both or a ep3 idler pulley to replace the PS.
-radiator, 02-05 civic si radiator or kswap radiator
-you will need a fuel pressure regulator and custom lines. Most people opt to buy an aftermarket fuel rail. (skunk2, hybrid racing, BDL,etc...)
-hybrid racing clutch line
-hybrid racing throttle cable
Reminder the list is kind of basic. It really depends on what motor you are using.
price guide: http://www.hondatuningmagazine.com/t...el_system.html
hondatuning: http://www.hondatuningmagazine.com/t...wap/index.html
Here are some helpful links from k20a.org
Online Honda/Acura OEM parts stores
http://www.k20a.org/forum/showthread.php?t=37610
**SWAP PARTS LIST: The thread to end all the questions.**
http://www.k20a.org/forum/showthread.php?t=20860
Honda/Acura Part Number List
http://www.k20a.org/forum/showthread.php?t=33132
Wiring and Pinouts
http://www.k20a.org/forum/showpost.p...8&postcount=16
some parts may vary depending on your build.
Sourced from: http://www.hondasociety.com/board/sh...d.php?t=146019
-motor
K20a Euro-R Accord
Wiring and Pinouts
t0p_sh0tta
Jun 10, 2014 09:47 AM
ESP-net
Jun 25, 2007 02:34 PM
