Removing Crx Door Trim
Old Nov 14, 2011 | 09:05 PM
Gremlin_rex's Avatar
Default Removing Crx Door Trim
Ok, so im missing the long skinny middle door trim piece, R side, i have another door that im going to try to take it off of and swap it over, been looking for an hr now on other forums and random sites on how to remove the trim ,saving the clips or not idc, prefer to save them, but there is no access by taking the door panel off, its covered by a another piece of metal welded onto the door, any suggestions?? ( im trying to use it because i cannot find this piece anywhere)
Old Nov 15, 2011 | 01:26 AM
m.e.s.a's Avatar
Default Re: Removing Crx Door Trim
unscrew the bolt at the end of the door, then try to pull it out and as soon as you see a clip, then use a flat screwdriver to to pull it out at the door. If you are careful enough you can remove it without damage
Old Nov 15, 2011 | 06:28 AM
alright so i just got it off, yes take that screw out on the edge of the door. but then push on the trim from the back side of the door sliding it toward the front and it comes right off, didnt break any clips..
bonestock91
Aug 12, 2006 01:12 AM
91hondacrx
Aug 19, 2004 06:53 AM
NtegraRacR05
Sep 15, 2003 06:57 PM
snake01
Jan 11, 2002 09:06 PM
