D16Z6 auto and manual redline difference?
Hi guys' Does the D16Z6 automatic and manual transmission has the same redline?(fuel cut), because I bought a 95 coupe EX with stock D16Z6 aut. and im getting the fuel cut at 6500rpm also my vtec worked about a few days after buying the car, Instaled a led on the vtec solenoid wire and it never came on flooring the gas pedal until engine makes the fuel cut, I have a new oil pressure switch, cleaned the solenoid gasket screen, 4.2qtz of oil, had no dtc codes, everything is working for now and I have no clue whats the problem.
If somebody knows what else can I check would appreciate your help Thanks.
variable
May 8, 2010 12:14 AM
krysted9354
12
Dec 30, 2008 07:40 PM
JamesV
Apr 27, 2006 03:38 AM
