Suspension & Brakes Theory, alignment, spring rates....
Rsx civic Si fit strut
Old Nov 14, 2011 | 07:48 AM
gotslicks's Avatar
Default Rsx civic Si fit strut
Does anyone know the difference in the front struts for the 03 civic 03 Si 03 rsx and early fit?
Will they all bolt to 01 civic knuckles?
Long story short I did a k swap on my insight an used 01 civic spindles and struts. I need to order coilovers but will only use the fronts because of the suspension setup on the insight.
But If I order the early fit setup I may be able to use the rear springs because the rear is setup similar to the insight?
Louiethegreat
Honda Civic (2001 - 2005)
Nov 8, 2012 02:57 PM
SiR_Injected
Aug 26, 2007 11:07 AM
alexsracing
Jun 4, 2007 05:02 AM
CC2
Apr 11, 2007 08:55 AM
Suprdave
Nov 8, 2003 07:14 PM
