Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Elec. Power Steering doesn't come on when it's cold outside.
Old Nov 14, 2011 | 05:09 AM
Meesheltx's Avatar
Icon6 Elec. Power Steering doesn't come on when it's cold outside.
I have a 2007 Civic Si. When it's really cold outside, the first time I start my car, everything comes on fine except for the electrical power steering. The problem started last winter and every time it happened, i would turn the car off and restart it and it would be fine.
This year, it's taking more than just 1 or two tries to get it to come on. I have noticed that if I leave it on for a longer time, I may only have to restart it once to get the EPS to come on.
I've submitted this question in other forums and the only feedback I've received is that I need to take it in to the dealers. Can you offer any more insight into what may be wrong before I take it in?
Old Nov 14, 2011 | 07:07 AM
bee guz's Avatar
Default Re: Elec. Power Steering doesn't come on when it's cold outside.
The only thing I might suggest is check all of the plug in's make sure they are clean and tight.
Something isn't powering up like it should on start, it could even be a broken or loose engine ground, check all of your grounding points also.
Is the car still under warranty? it may be the EPS itself that has a bad spot.
itsnotfast
Dec 14, 2013 07:32 AM
Corey_sl
Jun 3, 2010 04:49 AM
INDYGSR
Apr 28, 2007 08:54 AM
sohctodohc
Jan 17, 2005 11:10 AM
