Why does my B16 smoke at low rpm and at idle
Old Nov 13, 2011 | 01:56 PM
allums34's Avatar
Default Why does my B16 smoke at low rpm and at idle
last week i tried to get my valves adjusted but they still sound loose i was told its probably lost motion assembly. my engine is b16 motor skunk2 stage one cams rc injectors and the rest bolt on. my question, is this the reason my engine smoke at low rpm and at idle thanks
Old Nov 13, 2011 | 02:38 PM
Former User's Avatar
Default Re: B16 smokes at low rpm and at idle
Please place simple tech questions directly into thread title. --edited
Old Nov 15, 2011 | 11:47 AM
allums34's Avatar
Default Re: Why does my B16 smoke at low rpm and at idle
since i didnt get any help ill try replacing valve guide seals and go from there i have one engine code for tps sensor
Old Nov 18, 2011 | 07:08 PM
Markley02's Avatar
Sounds like it would be a valve stem seal. Intake valve at that. It should be the only thing that would cause it to smoke when only under high vacuum. So you figured it out yourself. BTW, fix the code!
lexruger
Aug 11, 2010 02:41 PM
xpdude
May 15, 2010 04:43 PM
h22_crx
May 6, 2008 11:31 PM
John F
12
Nov 28, 2007 08:00 AM
spaceman
Apr 19, 2004 08:48 PM
