car wont start
Old Nov 13, 2011 | 04:50 AM
young-gun92eg's Avatar
Default car wont start
ok so i have a 93 eg si. it will not start without a boost but as soon as you boost it it starts right up. but when i put the battery on the charger the charger says that the battery is alredy fully charged. and then when the battery is hooked up again and you turn the key on somtimes all the lights ect. will turn on and work perfect but then you try it again and nothing will work and the dome light will be a dim and blinky and then you try again and everything will work fine again. but nomatter what the car wont start like it wont even turn over it just makes a click sound and everything dies helppp
Old Nov 13, 2011 | 02:11 PM
grumblemarc's Avatar
The Grumpiest
Default Re: car wont start
Wow. Check the starter.
Old Nov 13, 2011 | 05:09 PM
i thaught that at first to. it ended up being the battery it went all wierd and acid came out off it, threw a diffrent battery on and it worked fine
white-eg
Mar 18, 2010 08:17 PM
sixfourkiller
Jun 17, 2009 10:05 AM
Ph0eNix
Dec 15, 2005 11:58 AM
KloC 95 EG
Dec 9, 2005 02:16 AM
