95 sedan engine will only turn over when the front end is on jack stands
I guess I was unclear in my last post so I thought I'd make a new thread to better help you guys understand.
I have a stock f22b2 with 244K miles. I can turn the engine over by hand ONLY if the front end is on jack stands, if it's on the ground it will barely budge. I took the head off and had it vacuum tested and all the valve seals where in good shape. The block doesn't look damaged at all, but it will not turn over unless it's on jack stands.
I'm going to take the oil pan off tonight and see if I can find the problem that way, but if anyone has any ideas, advice, or anything that could help me out PLEASE help fellow accord owner out!
-_____- it was in 3rd gear
Thanks for making me feel like an idiot!
Just kidding with ya, but I still gotta figure out this whole not starting issue, I'll update this when i find out more about the problem.
j4s0n1337
Nov 12, 2011 12:15 PM
