Signals and hazards blinking super fast, bad relay?
Old Nov 12, 2011 | 09:53 AM
pettyboy69's Avatar
Default Signals and hazards blinking super fast, bad relay?
Ok so I picked up a 98 integer to fix up and sell and iv gotten everything else fixed but this, at first I thought it was just burnt out bulbs but it's not. The blinkers blink super fast whenever I signal and also when the hazards are on. Would this be a signal relay or hazard relay?
Thanks in advance
Old Nov 12, 2011 | 02:27 PM
fcm's Avatar
fcm
Old Fart
Default Re: Signals and hazards blinking super fast, bad relay?
FYI, it's Integra not "integer", anyway it is possible that it is the "Turn Signal/Hazard Relay as both sides are effected, the relay and the hazard light switch are the only things common to both the left and right sides, because it is a "flashing" issue, I would guess it's the relay, but you will need to pull it and remove the cover to see if the "hyper flash" mod has been made, [one of the capacitors is replaced with a 4.7 50wv cap, if so you will need to replace it with a proper one or replace the relay. 94
Old Nov 12, 2011 | 03:11 PM
DirtyDA9's Avatar
If it's blinking really fast then the light itself is out.
Old Nov 12, 2011 | 03:47 PM
sebTeggy's Avatar
Acura Integer, Lmao!
Old Nov 13, 2011 | 11:29 AM
pettyboy69's Avatar
Sorry for the spelling my iPhone automatically corrected my spelling. It ended up being the signal relay
8dxhatchy8
35
Feb 16, 2009 06:49 PM
dalek
Dec 26, 2007 12:21 PM
90civicturboed
Jul 29, 2005 08:47 PM
