96 hatchback gsr swap axle help
i swapped my 1995 gsr motor and tranny into a 96 hatch and went to put my gsr axles in and seems like the driver side axles is about a inch to long the bottom ball joint wont go into the control arm. i thought all b series axles work??????
any help would be great and if i cant use my gsr axles which ones should i gte. thanks guys
All 94-01 Integra 5-speed axles will work for a B swap in a 96-00 Civic.
Make sure the inner joint is completely seated in the transmission, and that the outer joint is completely pulled through the spindle.
