dpfi restrictor plate removal
Old Nov 11, 2011 | 05:29 PM
crazyboy's Avatar
Default dpfi restrictor plate removal
some people have done it. are there any power gains from this? people say it makes the car run like ****, what kind of symptoms will this cause?
Old Nov 11, 2011 | 05:31 PM
crx_si-r's Avatar
Default Re: dpfi restrictor plate removal
if you want power gain swap over to an MPFI set up. otherwise dont waste your time on trying to squeeze power out of the DPFI set up.
Old Nov 11, 2011 | 05:34 PM
crazyboy's Avatar
well.... in for someone to actually answer my question lol
Old Nov 12, 2011 | 04:43 AM
all-motor-crx's Avatar
the little resistor plate is held on by one screw if i do recall it was used to boost fuel economy. it'll only add a very small amount 5hp?. its a quick and simple way to add a little bit more air but imo it's not really worth it. b2's have **** for hp anyways slap on a mpfi lol
if you want hp gains throw on a a6 cam and a y7 gear
Old Nov 12, 2011 | 06:26 AM
Canadian_EF's Avatar
Maybe 5HP if you are lucky.
Dpfi is great since it is restricted, you get good fuel economy.
Same idea as removing the dpfi box and just putting an air filter on it.
But you are still trying to make lemonade out of oranges.
Old Nov 13, 2011 | 06:33 AM
mississippi_ef's Avatar
Removing that small, v-shaped plate isn't going to do much for 'performance', if anything it's just going to make your intake sound louder during acceleration. It's more of a baffle than anything.
Old Nov 13, 2011 | 08:52 AM
jdmboyef9's Avatar
"Took the restrictor plate off to give the Red Dragon a little more juice. But it's not exactly street legal, so keep it on the down low."
Old Nov 13, 2011 | 07:22 PM
uberEFtuner's Avatar
If you are referring to the egg shaped plate before the throttle plate. I have removed it from my car and a friends car, with no ill effect. It just sounded better. It probably gives the engine .5hp at 5,000-6,500rpm. Not a big deal. And you can re install it if you want.
Old Nov 14, 2011 | 07:10 PM
crazyboy's Avatar
well i dont have a b2 i have a cx block with an a6 head thats still dpfi (unfortunately) and i was asking because the people i got this car from have it removed and i want to put it back in for smog (which has gotta happen anyways) i just dont want to starve the engine for air and **** something up. i was just curious as to why they would remove it
maiden424
13
Oct 28, 2014 09:40 PM
Raf
Jan 18, 2005 09:24 PM
Raf
Jan 3, 2005 09:01 PM
GumballNA
88
Oct 25, 2004 03:59 PM
H22A EG6
Jan 12, 2004 05:36 AM
