Clutch slave cylinder?
Old Nov 11, 2011 | 04:25 PM
Juans_MX3's Avatar
Default Clutch slave cylinder?
So ever since its been getting really cold in Utah, my clutch pedal started to become looser and looser.
It got to the point the other day where I cant get the car in reverse or 1st gear.
Two scenarios, a cracked clutch line (I doubt... i hope not) or the clutch slave (right by the tranny).
Tomorrow I am going to try bleeding out the clutch. The clutch fluid is full (brake reservoir).
Any other possibilities?
Old Nov 11, 2011 | 04:30 PM
grumblemarc's Avatar
The Grumpiest
Default Re: Clutch slave cylinder?
With car OFF. Can you get into all the gears?
Old Nov 11, 2011 | 04:32 PM
Juans_MX3's Avatar
With car off yes, I can get it in all gears. But the clutch is waay loose now
Old Nov 11, 2011 | 04:33 PM
Juans_MX3's Avatar
When I try to put it in gear when the car is on, all it does is grind.
Old Nov 11, 2011 | 04:51 PM
The Grumpiest
Bleed line. Replace slave cylinder if that does not work.
Johnoolo
Nov 18, 2013 12:54 PM
92redhatch
Jan 25, 2008 04:31 PM
markski037
Dec 21, 2005 05:13 PM
Greenery18
Jul 8, 2005 04:22 PM
VTC_CiViC
Nov 17, 2003 08:10 AM
