Built 97 b18c1 part out!
97 b18c1 straight out of my 97 gsr LEGIT! The motor has 10,000 miles on it was just broken in when my oil pump wen't out. I thought I had spun rod bearings so I took it apart and what do you know everything was okay except the oil pump. No more time and money to fix it so I gotta sell it The whole motor is still good just needs to be re-assembled since I took it apart to check all the bearings which means it needs a new headgasket and the head to be resurfaced.
PARTING OUT UNLess someone wants the whole thing. Only 10,000 Miles on everything!
RS machine sleeved b18c1 81.5mm block - $1100 (will come with main caps, ARP main bolts, RS machine block ghirdle. Go to rsmachines.net look at the Magnum Bseries open deck block and it looks exactly like that)
81.5mm Arias forged turbo 9:1 pistons with rings still good - $350
LS Eagle Rods - $200
LS crank - $100
b18c1 ARP Head studs - $80
97 b18c1 Head with full valvetrain - $600 Bare head - $250 with all bolts and caps
Supertech Dual Valve springs (85lb) - $100
Supertech Ti Retainers - $150
Supertech SS Flat valves - $200
This motor has everything on it (oilpan, etc...) Besides the Intake manifold and Valve Cover since I sold those already. I will take Resonable OFFERS ONLY! Don't try to offer me a stupid low price cuz it will be ignored.
FOR PICK UP ONLY IN SAN DIEGO/ESCONDIDO, CA or FRESNO, CA!
You can call me or text me at 559-824-9599 if you wanna check it out or find out more info on it. I will not waste my time and meet up or show the motor to you unless you have cash in hand and ready to buy (**** FLAKERS). This motor is Legit and everything is in Good condition.
LS crank - $100
