Check engine light, Obd2 car with obd1 ecu
How can i check what the code its throwing??
All the obd2 scanners indicate a syncing problem, most likeley because its an obd1 ecu.
OO Integra, p28ecu w/hondata
Its raining out here i havent checked for that connector. I thought only the 94-95 had that service connector, and the obd2 cars only had the obd2 plug. Ill check if its there.
Are you shure the obd2 cars have the service connector??
Ill check ia as soon as i get off work and it stops raining.
Yes, OBD2 cars have the service connector too. You're supposed to jump the connector when you adjust ignition timing. And of course it will give you DTC codes without using an OBD2 scanner.
