Sensor Repin
Old Nov 11, 2011 | 11:20 AM
guessohw's Avatar
Default Sensor Repin
Quick question. I have to repin my air intake temp senor and I need to know if it matters which side I put which wire in? The AIT sensor I am taking out is from a 96 civic ex and I am swapping it with a 92-95 sensor. The wires dont match so that is why I am asking. Thanks
Old Nov 11, 2011 | 11:57 AM
93egSLEEPER's Avatar
Default Re: Sensor Repin
They should be the same wires, just different colors.
Old Nov 11, 2011 | 12:04 PM
guessohw's Avatar
Right but which pin goes in which? Is there a diagram or I guess Ill just go by trial and error. Thanks
Old Nov 11, 2011 | 12:06 PM
jjmose03's Avatar
get a ohm tester and that will solve your problem fast... hate to short out a ecu or something
Old Nov 11, 2011 | 12:15 PM
guessohw's Avatar
good thinking. Thanks
Old Nov 11, 2011 | 02:18 PM
apexi_rsx's Avatar
or just test it by taking the pins out of the plug and sliding it over the pins in the sensor in different combination until you have no CEL. Then repin the sensor as you have it temporary pined on the sensor and you should be good to go.
Old Nov 11, 2011 | 02:50 PM
HondaPartsHero's Avatar
Technical Hero
doesn't matter which wire goes where
voz
Feb 18, 2010 04:34 AM
bopbop93030
Audio / Security / Video
Aug 14, 2009 06:15 AM
743power
Jan 23, 2006 06:11 PM
