fog light fitment
i was wodering if these fog lights would fit on my 89 crx i dnt have a mounting bracket just the fogs wiring and switch
so what would i have to do for these to fit and work??
if you took pics of the ones you intend to install it seems that the mounting hardware is right there...you make a hole in your bumper cover, put the threaded stud through and the nut/washer on it...as far as the bulbs you would need to open them up and see what is in them...assuming the pics are the ones that yo uare about to use.
hard to say how you would go about mounting them. i used the same brackets on yours, i just drilled a whole and stuck it through and bolted it up. and yea h3's should work, but check and make sure b4 you buy them
there gunna go in the oem bumber
so just kut out the whole for the fogs then the one for the mouting bracket wire them up and i should b good right?? would i come upon any problems insalling these fogs on the oem bumber??
I am blown away by the lack of knowledge... Si bumper? Lmfao
To the OP, if you look at the inside of your oem bumper you will see the outline for the location of the oem fogs. As far as "can someone tell me if they will fit" they are not OEM so the fitment comes with the skill of the mounter. Just remember to measure twice (maybe three times in your case) and cut once. It wont look oem but it is your car. Just take your time and dont cut corners.
JesseCRX
25
Aug 27, 2009 09:18 PM
teddybruckshot
May 17, 2006 04:39 AM
1989, 89, crx, dimensions, diminsions, ef, fitment, fog, foglights, honda, installing, light, lights, mount, sizes
