ZCSpeed Adapter Plate, Skunk2 Intake Manifold,Thermal Gaskets, B18B TB DOHC ZC
I had this setup on my DOHC ZC (with adapter plate), money is getting tight so I will have to sell this and use a stock intake manifold. Most parts shipped USPS Priority Mail within 2 days. Paypal only, send as gift or add 3% for the fees.
I got a Skunk2 Intake manifold (SOHC D16). It's in good shape, it's unported but the throttle body opening has been bored to 68mm (you can still use smaller TB without any affect). I can powdercoat it for an extra $25. The only thing is one of the throttle body hole was drill and tapped with slightly larger thread size, I just reamed out the hole on the TB slightly and it works fine, doesn't affect anything. It will come bare (no fuel rail, injectors, sensors, hoses are included). I would like to get $190 shipped (shipped UPS Ground most likely)
I also have a B18B throttle body. It's 60mm and is getting harder and harder to find. It doesn't come with MAP or TPS Sensor (+$10 for MAP Sensor). It's clean and I put a fast idle solenoid block off plate on, but you can take it off and run it. I might have the fast idle solenoid lying around if you want. $45 Shipped
Then I have some thermal intake manifold gaskets. I have a Blox (if I remember correctly) DOHC ZC gasket and a SOHC D16 Password:JDM Gasket. I love these because you can reuse them over and over, I spend over $35 each, so I would say $20 shipped each.
prelude182
Jan 7, 2010 12:34 PM
Mr. Winky
Sep 7, 2008 11:26 AM
