b18 to b20b swap help
Old Nov 10, 2011 | 07:41 PM
jojousmc23's Avatar
Default b18 to b20b swap help
Sup.Got a 1994 ls that was boosted but my evolution wastegate took a crap on me and blew my b18 to bits along with frying the turbo. Ended up throwing a connecting rod str8 threw the block. So i ended up picking up a jdm b20 and was planning on going back n/a for a while. Everything bolted up just fine except I cant get it to run for more than about 4 seconds before it dies. I know my timing was off at first cuz it was backfiring and wouldnt start but after re adjustment I can get it to turn over and start warming up at 2000 rpm for about 3-4 seconds but it just dies before it can start idling. Everything should be hooked up correctly. I did end up using the distributor from my b18 but i dont know if that would really be a problem. Any help would be appreciated. Thanx
Jojo
Old Nov 10, 2011 | 09:08 PM
mark@silbernage's Avatar
Default Re: b18 to b20b swap help
Did you use the same or different ECU? Any chance the pressure spike damaged the MAP or ICM?
Old Nov 10, 2011 | 09:16 PM
jojousmc23's Avatar
Still running the same ecu. All the sensors seem okay but i never even considered that. Definitly gonna check that out.
Old Nov 13, 2011 | 06:14 PM
jojousmc23's Avatar
Yup. It was the ecu. My ecu is still turbo chipped. (Cant believe I forgot). So I pulled the performance chipped out of the holder on the ecu and threw it back in and started right up. Ran terrible so I still need another ecu but i least i know what the problem was. Thanx for the help boss.
Old Nov 14, 2011 | 08:33 AM
thehoustonian's Avatar
nice, looks like you dont need help. anyways for a chip for my b20z i just ordered one from phearable.net and it worked flawlessly, passed emissions and gets about 24-26 mpg with 98 itr gearing might be worth it to check it out
egcrazed
Mar 25, 2013 12:14 AM
striker5661
Oct 13, 2011 11:23 PM
kurs
Jan 25, 2009 12:27 PM
SIC_jdm_da9
Nov 9, 2007 11:44 PM
crazyhtch
Dec 3, 2005 07:00 AM
