do you know?
90 crx si. ive replaced with brand new distributor, spark plugs, wires, battery, alternator, fuel pump, fuel filter. it still wants to sputter as if its ran out of gas. i pulled the fuel line off and primed it into a bottle and theres no gunk in it. this thing is seriously pissing me off. does anybody know wtf this might be?
Is the check engine light on? If so check the ecu for codes, my guess would be anything from a faulty main relay, thermostat ground, o2 sensor or tps sensor since you replaced everyhting else that would be the problem.
compression test, timing (mechanical and ignition), and other stuff. You've just been throwing parts at it, not troubleshooting it. I'm sure the car is more pissed off at you.
the check engine light isnt on, and the grounds are good. i have a new tps for it, just havent put it on yet. im just tryin to get a few suggestions before i start pullin the throttle body off and bust out the dremel. im kinda hoping at least one of yall have experienced this and know wat it is
netfreak
Aug 29, 2018 04:57 PM
