quick injector question
Old Nov 10, 2011 | 06:22 PM
tyvtec23's Avatar
Default quick injector question
i have obd1 injectors from a 92 DA but they dont fit my crx si harness cause im guess the jump from odb0 to obd1? also i cut ond1 injector pulse clips and wire them to my obd0 harness would it still work?
Old Nov 10, 2011 | 06:32 PM
crx_si-r's Avatar
Default Re: quick injector question
no. the DA injectors are saturated (non resistor box). and a CRX uses Peak/Hold (resistor box). if you want to use the DA injectors you will also need to remove the resistor box
Old Nov 10, 2011 | 07:01 PM
tyvtec23's Avatar
id rather buy recommended injectors, which would you say is best or what kind can i use along with the resistor box
Old Nov 10, 2011 | 07:11 PM
crx_si-r's Avatar
stock injectors from any 88-91 si or 90-91 DA.
or also any 92-00 civic/integra will work. you will need to delete the resistor box with these injectors.
immorality
May 24, 2008 03:46 PM
SFlCrx
Mar 21, 2007 05:48 PM
GoFastMotorSports
Jan 17, 2005 02:43 PM
90crxb16a
16
Oct 28, 2003 01:44 PM
Jeff C
Apr 22, 2003 12:37 PM
