Suspension & Brakes Theory, alignment, spring rates....
95 hatch dx brakes sticking
Old Nov 10, 2011 | 05:33 PM
andyhundley's Avatar
Default 95 hatch dx brakes sticking
i have a 95 honda civic dx hatch non-abs disc/drum. about 6 months ago the front brakes would stick intermittently in the front. it was weird because the problem initially was in the driverside but then it would stick on the passengers side or sometimes both. so we replaced the master cylinder with an A1 Cardone reman. master cylinder. it was fine for about a week thinking that the problem was solved but it came back. so i then replaced both front calipers and brake hoses and the problem of them sticking still occurs. its wierd because they will stick really bad to the point where i have to pull over and i can let the car sit for five minutes and then the brakes dont drag and its fine again. i have only bled the system by using a wrench on the caliper and am curious if i should try one of those vacuum bleeders for there might be air still in the system causing the issue. or possibly a pinched line. the only thing i havent replaced is the booster and prop valve but those are both spendy items from the dealer and would rather not guess. if anybody has any advice that would be great
thanks andy
Old Nov 14, 2011 | 05:34 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: 95 hatch dx brakes sticking
Adjust the master cylinder push rod.
Old Nov 14, 2011 | 05:58 PM
slowturbocx's Avatar
He's right.^^^^
andyhundley
16
Nov 11, 2011 07:01 PM
motrayEG6
Nov 25, 2010 06:35 PM
Jowee
Jan 14, 2007 01:37 PM
dem0nk1d
Jan 11, 2006 06:12 PM
sleepin91teg
11
May 31, 2005 12:09 PM
