EF Hatch B16A swap problems...need help please
Old Nov 10, 2011 | 10:59 AM
JHammondCincy's Avatar
Default EF Hatch B16A swap problems...need help please
Ok I bought this car with the swap already done...i know but they did a decent job and man it ran hella good when i bought it too.
Well now my wife was driving down highway and lost all power.....
after a week of trying to figure out what distributor to get we finally got the right one and the right fit ODB0....
well now that I have the new dizzy n....it ran like **** big time...NO POWER at all.
I replaced fuel filter and the plugs were shot so i put new Bosch Plat 4 today and its finally starting but NO POWER at all...when i hit the gas it just wants to die...i might be able to hit 3k once or twice but then it gets worse and almost dies.....help me please.... I unplugged the map sensor and thats not the problem....my buddy thinks its the TPS....any help would be great...
Thanks in advance
Jay
Old Nov 10, 2011 | 01:42 PM
stackedhouse's Avatar
Default Re: EF Hatch B16A swap problems...need help please
Are your plug wires in the correct order?
Old Nov 10, 2011 | 01:45 PM
yea i checked that last night
im very confused
Old Nov 10, 2011 | 01:57 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Did you actually set the ignition timing? You can't just slap a distributor on there and call it good, especially on an EFI engine.
Also, throw those Boschs in the trash, they are garbage.
Old Nov 10, 2011 | 02:19 PM
4drEF's Avatar
Keyboard Humorist
Any ECU codes?
Am I reading it right that you are OBD0? (just checking)
Old Nov 10, 2011 | 05:54 PM
Originally Posted by 4drEF
Any ECU codes?
Yea I installed an OBD0 distributor
Old Nov 10, 2011 | 05:56 PM
Ouch i just bought those dang things...and im on unemployed freelance income lol...
But please explain the ignition timing cause i did not do that and would that cause the "No Power" at all problem?
Old Nov 10, 2011 | 06:08 PM
crx_si-r's Avatar
what ecu are u using?
Old Nov 10, 2011 | 06:39 PM
Im very new at this...how do i tell what ECU im using?
Old Nov 10, 2011 | 06:49 PM
crx_si-r's Avatar
on the side there is a label like:
Old Nov 11, 2011 | 08:02 AM
4drEF's Avatar
Keyboard Humorist
Any ECU codes?
Got that part, but your distributor needs to match your ECU so we need to know what exactly you have.
Please provide which ECU you have as well as the numbers on your distributor (vtec and non vtec distributors are different internally)
Old Nov 14, 2011 | 05:08 AM
OK np thanks for your help...my car is still down and the wife needs it back lol....sucks bumming rides and not being able to take your daughters where they need to go.
Ill snap some pics too.
Old Nov 14, 2011 | 06:03 AM
Ok here we go.
Old Nov 14, 2011 | 06:07 AM
and the new distributor
Old Nov 14, 2011 | 06:40 AM
4drEF's Avatar
Keyboard Humorist
And that really doesn't help at all.
Need the actual stamp number on the distributor and the barcode number on the ECU.
Distributor code is usually found on the side of one of the 'ears' that bolt to the head..
[TD-01] Civic/CRX DPFI 1988-1991
[TD-02] Civic/CRX MPFI 1988-1991
[TD-03] OBD0 DOHC ZC Civic/CRX 1988-1991
[TD-22] OBD0 B16 Civic/CRX/XSi 1988-1991
[TD-23] OBD0 B18a Integra 1990-1991
[TD-31] Accord 1990-1991
[TD-41] Civic D15b Non-VTEC 1992-1995
[TD-42] d16z6/d15b VTEC 1992-1995
[TD-43] OBD1 DOHC ZC 1992-1995
[TD-44] OBD1 B16/GSR/ITR VTEC 1992-1995
[TD-46] OBD1 b18a/LS/B20/CRV 1992-1995
[TD-52] Accord 1992-1993
[TD-55] OBD1 b18a/LS/B20/CRV 1992-1995
[TD-60] Prelude H22a 1992-1996 JDM
[TD-63] OBD2 99-00 OBD2 Civic D-Series Non-VTEC
[TD-68] OBD1 B16/GSR/ITR VTEC 1992-1995
[TD-73] OBD2 99-00 OBD2 Civic D-Series Non-VTEC
[TD-84] OBD2 B16/GSR/ITR VTEC 1996-2001
[TD-89U] Prelude H22a 1997-2001 JDM
ECU code is found on the side of the ECU and looks like this
[img][/img]
Old Nov 14, 2011 | 08:28 AM
91efbluehatch's Avatar
Originally Posted by JHammondCincy
Ok here we go.
looks like a JDM pr3-JOO
Old Nov 14, 2011 | 12:30 PM
my distributor is
TD-22U
I really hopes this helps
Old Nov 14, 2011 | 12:47 PM
Heres the ECU code
Old Nov 14, 2011 | 12:54 PM
codybuRr's Avatar
theres a difference between a vtec dizzy and a non-vtec dizzy yo
Old Nov 14, 2011 | 01:01 PM
4drEF's Avatar
Keyboard Humorist
^^ trying to find out what distributor he has!
I doubt that D11 translates to TD-11.
TD-11 is from an Acura Vigor and I highly doubt that's the distributor you have on there.
Take the distributor off the head and look around on it for a different number.
Old Nov 14, 2011 | 01:03 PM
Its a:
TD-22u
Old Nov 14, 2011 | 01:08 PM
4drEF's Avatar
Keyboard Humorist
Ah - got the edit. cool!
You got the right stuff!
Seemed like a hassle and a waste of time, but if the distributor didn't match the eCU it would have been an instant fix.
Old Nov 14, 2011 | 01:15 PM
No im good with double checking....but any clue what is wrong with my car....it ran hella good before the distributor went out...now im stuck with a car that starts but no power at all.
Old Nov 14, 2011 | 01:59 PM
4drEF's Avatar
Keyboard Humorist
No, I dont =/
Never had a problem that was the REAL limp mode. Usually I get CEL light and codes that tell what the problem could be.
I am not even convinced your distributor was the problem. You replaced it's not fixed.
Almost sounds like the timing belt hopped a tooth.
Probably a good place to start.
Old Nov 14, 2011 | 03:06 PM
No, I dont =/
When we took the distributor out it wouldnt spin and when we got it to spin some plastic pieces came out and just went from there.
Just pulling at straws but could it be the injectors? and is there a way to clean them your self?
