crx gas smell problem
That's because you are washing the cylinders with fuel... You have a spark problem or an injector/s stuck open. I would start with spark and go from there...
what do you mean spark problem? as in when im cranking the cylinder is just getting filled with fuel? and would i have to changed the injector or just the harness clip to the injectors
There isn't enough spark to burn the fuel, so yes, you're just pumping fuel into the cylinder.
Pull your plugs and see what they look like to start with.
Might be a good idea to check the amount of spark at the plug end of each plug wire too.
Depending on the results of that you may have corrosion on the dizzy cap or rotor, among other things.
the spark plugs are pretty much new but im gonna check anyways, the injector i have on there are 440 dsm injectors but they worked great on my other ls, would this have an affect also?
Ugh... you can NOT use injectors much bigger than stock without having the ECU chipped for then
Your ECU still pulses the injectors like you have the 240cc injectors. So in other works you are almost doubling the fuel at all parts of the map. You better hope you didn't wash the cylinders and mess things up.
Also, on a bone stock LS - there is absolutely NO reason to use anything other than stock. The head flows like crap and there is no reason to change a thing. If you had some major work done or forced induction then it would be justifiable.
Fatty_1775
Jun 12, 2007 10:40 PM
Sanj
Feb 12, 2006 05:56 AM
nd94cx
Sep 21, 2004 07:29 PM
