obd0 to obd1
Old Nov 9, 2011 | 09:39 PM
10psiLsEf2's Avatar
Default obd0 to obd1
Whats up guys just picked up a obd0 to obd1 from a local shop i connected a p28 to it and no start!
Do i have to wire other things? i thought it was just plug n play!
Please help
Thanks
Old Nov 10, 2011 | 01:20 AM
HondaPartsHero's Avatar
Technical Hero
Default Re: obd0 to obd1
Make/model/year/engine? If you have an OBD0 car and are simply trying to use an OBD1 ECU you also will have to use an OBD1 distributor as well (using an adapter harness or rewire) as the OBD0 and OBD1/2 distributors aren't compatible with each others ECU. Once you've done that it should start but you're going to have some check engine lights for O2 (you'll need to wire to 4 wire) and VTEC codes if you haven't connected the VTEC wiring.
Old Nov 10, 2011 | 11:08 PM
10psiLsEf2's Avatar
91 civic b18b1 going boost so need obd1 to get tuned.
can i just buy a obdo to obd1 dizzy jumper or do i need obd1 dizzy
thanks bro
Old Nov 11, 2011 | 02:57 PM
Technical Hero
You need a jumper and OBD1 dizzy unless you feel like rewiring the OBD1 distributor plug yourself with the OBD0 plugs.
Old Nov 11, 2011 | 07:36 PM
10psiLsEf2's Avatar
Ok thanks hondapartshero
munchies91crx
Sep 5, 2009 01:40 PM
darrenVT
Engine Management and Tuning
18
Sep 30, 2008 09:18 AM
EnSAn
Jun 3, 2006 03:12 PM
lsvtec90
Nov 22, 2005 09:01 AM
skud_dusty
13
Apr 25, 2003 11:51 PM
