oil temp and oil pressure from same fittingq
Old Nov 9, 2011 | 08:05 AM
raverx3m's Avatar
Default oil temp and oil pressure from same fittingq
anyone here running both gauges(oil temp and pressure) from same fitting.
i was wondering how can i make both sensors in the same place where would be the best place to mount them .
that way i dont have dingleberrys and wires hanging everywhere.
Old Nov 9, 2011 | 08:14 AM
grumblemarc's Avatar
The Grumpiest
Default Re: oil temp and oil pressure from same fittingq
Sandwich adapter.
Old Nov 9, 2011 | 10:54 AM
raverx3m's Avatar
can the stock b16 sandwich adapter be modified?
and as far as i remember theres also the coolant lines running through it.
then i can add the coolant temp sensor also.
which one would you recommend or maybe that has all 3 fittings.
the aftermarket sandwich plate repaces the stock one right?
i have all 3 gauges thats why i was asking.
Old Nov 9, 2011 | 10:58 AM
The Grumpiest
I use aftermarket. I didn't know B-series had one stock. Check eh Golden Eagle ones. I can't remember which one I bought for my gauges. It's essentially just a hunk of metal with fittings and an o-ring.
Old Nov 9, 2011 | 04:31 PM
raverx3m's Avatar
well its more of an oil cooler.
Old Nov 9, 2011 | 05:26 PM
h2.4's Avatar
the oil temp gauge's thermocoupler is too big to fit in a 1/8th inch pipe fitting.
MnEm1
28
Sep 24, 2009 03:46 PM
DC4_MADMAN
Aug 20, 2006 09:24 AM
CivicMike
May 26, 2005 09:34 AM
97AccordCD5
Dec 13, 2004 02:18 PM
d8168055
Jan 6, 2003 06:52 PM
