2003 Accord Idle Problem :(
Hi!
I have a 2003 Accord, 2.0i CL7. Nowadays at morning time in 0-5°C I go to work.
when I start the car the idle speed is 1600-1900rmp, I think is already to high a little bit and when I arrived my workplace (10km in town) the water temperature is in the middle (on operation temp), the idle also a little bit high 1000-1200rpm.
The idle speed is equally runs, nothing fluctuation.
What should I check? What can be the cause of this problem?
Thanks for Your helps!
Hi!
Today the weather is warmer here, so I could work on the car.
I disassemble the IACV (Idle Air Control Valve) and cleaned it and now the work good like before!!
Ir you have any more trouble with the high idle, I believe there is a PCM update to correct the high idle.
I still have this problem :-(
I have exactly same like this:
http://www.driveaccord.net/forums/sh...d.php?p=973459
JDEIRL
Apr 16, 2017 08:14 AM
