rear camber adjustment
Looking at my AP1 I notice the rear has camber bolts on lower control arms. Is this an OEM item? How much negative rear camber can I get? Approx?
Thanks
Thanks
thats stock and it dosent only adjust camber but toe too. i wouldnt touch it if the car isnt on an alignment rack
if ur stock suspension u should be able to get -3 if ur lowered u can get more.
i have mine set up at -2.3F and -3R dropped on espelirs
Wazup
Suspension & Brakes
Apr 29, 2005 08:10 PM
Andrew 825SM
Aug 15, 2003 03:16 AM
rioninja
Aug 22, 2001 02:21 PM
2011, adjuster, adjusting, adjustment, arm, bolt, camber, control, correction, honda, negative, pilot, rear, s2000, suspension
