91 civic dx d16z6 swap fuel pump wont stop priming
Old Nov 8, 2011 | 02:30 PM
lazylegs15's Avatar
Icon2 91 civic dx d16z6 swap fuel pump wont stop priming
ok, so i have a 91 civic dx sedan. i just recently did an engine swap to obd1 d16z6. everything seems to be ok aside from the fact that the car wont turn off with the key. also the fuel pump continues to prime. no check engine light or anything. its starts up fine. im stumped as to what to do. i used the dx wiring harness, removed the dual point injector wires(red-yellow/black, yellow-yellow/black) and ran the wiring from the mpfi. all four injector wires with yel/blk and ran them straight to the ecu(p28 auto converted to manual). i ran the vtec wires along with the four o2 wires and two cyp wires to distributor. i didnt cut any wires from the dx harness and i soldered and heat shrinked everything. ive already tested the main fuel relay, and the ignition switch and they checked out fine. am i missing something? any help would be greatly appreciated.
as of right now i just have a kill switch running to the yellow/green wire on the distributor to shut it off for a temporary fix.
Old Nov 8, 2011 | 04:06 PM
lazylegs15's Avatar
Default Re: 91 civic dx d16z6 swap fuel pump wont stop priming
anyone? could it be the ecu?
Old Nov 9, 2011 | 03:59 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
You waited a couple hours to post again?
There are way too many variables... I would suspect wiring.
It could be:
Wiring
Jumper Harness
ECU
Main Relay
Brandon L
Apr 9, 2014 11:41 PM
convic23
12
Oct 27, 2006 06:47 PM
blitzrican22
May 10, 2005 07:45 PM
wood
Mar 31, 2005 07:25 PM
TurboEH2
Sep 17, 2003 05:29 PM
