91 std not starting
I changed my oil, installed new spark plugs and a wire set and the car ran great for the rest of the day. The next day I try to crank my car and there's only 1 loud click and that's absolutely it. I've checked the main relay, starter, battery, there's fuel and a spark, and no codes. I've been able to push start my car for the past month but I just now replaced my battery cable because of extreme corrosion (thought it could be related to my starting problem) and now the battery light stays on and my starter is locked up. Tried rocking the car and banging on the starter with a hammer, won't push start anymore. I'm stumped
check your grounds...you can jump a ground to the starter body and a hot to the solenoid to see if it cranks...if this works its more than likely your main ground cable
checked the ground and cleaned the connections, got the light to go away. still won't crank, only the 1 click and I can't push start because the starter is still locked up
if it was my alternator, would it drain my battery completely? i have a starter laying around from a d16z6. could i use that on the d15? i had a guy from autozone telling me since my car is a 4 speed it won't work but it wouldn't be the first time they lied to me lol
Could be you have a short to your starter somewhere (internally or externally) making it locked.
Disconnect power to it and see if your battery still drains.
Try the alternator. The alternator drained my battery all the way down, and was doing the one click thing with me too. I just swapped it with a new one and it worked
D7KWagon
Aug 8, 2014 02:57 AM
AVXHATCH
12
Jul 6, 2003 05:08 AM
